Brake lights not working
Ricky Olivares
Las Cruces,NM
Ricardo
Blazer
Good morning, new to this site. Pretty cool how square body community gets together to help out. Anyways. I bought a 1985 Blazer 4x4. I got the brake light fuse popping every time I connect brake light switch. Wire gets hot. I’ve changed turn signal switch at steering column. Traced wires to brake lights. And checked for grounded wires in back of fuse box. I also don’t have right turn signal light not working. Changed flasher. Then pops fuse for turn signals. When ignition is on. Dash lights go on. Without turning on lights. Lights work when headlight switch goes on. Also dash lights work. They put after market front amber lights in front with led lights. I’m thinking it’s those lights. Causing electrical problem. I hate electrical.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
350 w/203
Possible short on the rear harness. I'd start looking from the back on both sides to the front.
1973c10
Don
Welcome
WFO
Texas Panhandle
dvdswan
Port Orchard, WA
Dave
Welcome to the site.
There is an electrical plug in the rear harness up under the back bumper near the frame, and its where you would plug in an adapter for a trailer wiring harness. If you disconnect that plug it should also disconnect the taillights from the system. That may be useful for troubleshooting/isolation. The harness also has a larger gauge white wire (12 gauge?) near there, which is used to ground the wiring harness in the back.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
What he said. If you unplug the rear harness and it stops, that makes your job somewhat easier. If someone did work under there recently and a wire got pinched, that’s where it’ll be.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Just as well to Check in behind the taillights as there’s a ground that sometimes has a poor connection to the body over time and a good time for a new set of bulbs
moved this to a more appropriate subforum :waytogo:
KennyB
