Brake light switch mounting
Dan Brown
Katy, Texas
355 (.030 over 350)
Restoring a 1974 K10. Am wiring it now, and when I went to put the brake light switch on, I realized that the switch activate button wasn't even close to contacting the brake pedal lever. It's been so long since I took the truck apart, I can't remember how the switch got activated. Is there some other bracket that mounts to the pedal lever that makes it contact the switch button? If anybody can post a picture of how this works, I'd really appreciate it.
Thx a lot.
Dan Brown
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
There should just be a small flat tab on the brake pedal arm, just right by the start of the bottom of the dash.
Thx a lot.
Dan Brown
There should be an "L" shaped striker that is bolted on to the brake pedal arm. That striker is what makes contact with the brake switch button. When the brakes are in the released position (pedal is up), it pushes on the button and holds the switch contacts open. Depressing the pedal moves the striker away from the button which allows the contacts to close. Some images of the striker and install/adjust instructions from the 74 service manual:
Dan Brown
Katy, Texas
355 (.030 over 350)
Found the old bracket, thx for the help.
Dan Brown
Katy, Texas
355 (.030 over 350)
Do any of you Square Body experts know what this bracket is for? Thx for any help.
1973c10
Don
manuelCuellar
Katy
Manuel
LS1
Hello! Any chance somebody knows where can I get this push rod for a 1985 C10 truck? Original is lost and I can't seem to find a replacement anywhere. Thank you!
Hard
