Brake drum replacement question
Blue79
alberta
Caden
Hi I am about to replace the drums on my c20 it has a 14 bolt axle and the hub is in front of the drum how would I go about taking off the hub from the drum do I just knock out the lug studs and it comes off or am I miss something
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Yep. Pull the axle shafts, pull the hub nuts and locks off, pull the drum and hub off, knock out the lug studs.
BurbanPena
Idaho
V1500
if you can get your hands on a brass punch or bronze punch it will save your lug nuts from mushrooming i use a bronze punch that is thicker then the lug nuts and have never had an issue
Auburn, Washington
Or just spin a sacrificial lug nut on and use it as protection for the lugs when pounding them out.
FenderBanger
