Body installation
pnak2003blazer79
ct
Petr
K5 Blazer
It’s possible to install 79 or 77 Blazer body on 1985 military Blazer frame . Will all mount holes match??? Should I use 85 body mount and just drop this earlier years cab on? Thank you.
SDJunkMan
Black Hills of South Dakota
Jeff
Welcome! I can't give you an exact answer, but there is a difference in the pickup mounts between the early style (80 and o!der) and the newer ones. They can be swapped with some slight modifications, so I am guessing the Blazers would be similar. I'm sure someone here will be able to tell you for sure.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
As far as know, the half can style blazers, (76-91) have the same if not very similar mounts.
The 73-75 full vert models were a little different. I believe it had lightly more bracing because of the lack of support in the roof. They are all the same size bodies, any blazer body should technically fit on another blazers frame physically, just depends on the work you want to go through. Dont see why it wouldnt work though.
I have both a 84 military blazer and a 75 full vert blazer, I would be willing to do measuring if you need. They look pretty much the same underneath.
May I ask why exactly your looking to do this?
1977chevyc30
