Blinker problems
75squarebody
Missouri
Alex
ok trying to make since of this the turn signal cam was broke on my 75 so I changed it left side turns work great right sides work good until you put on the brake then they stay solid until you take your foot off the brake any ideas did I do something wrong putting the steering wheel back on any ideas?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
I would start with checking the grounds at the RR tail light.
eskimomann209
Modesto
Marcus
Mine did something similar and it was an issue with the HEADLIGHT wiring. Over current in the system is a huge issue here.
Make sure your blinker bulbs are all working.
75squarebody
Missouri
Alex
They work fine as long as you are not on the brake if you get on the brake pedal then the right side just goes solid.
Doppleganger
OH-MI: Just like it sounds
Sounds like a short / back feed.
Like C10MixMaster said - check the grounds, and even the power source at your switch. Thats the 'connections' (no pun intended) between a turn signal and brake lamp. I would use a continuity tester on a DVOM and see what circuit(s) are connected that shouldn't be.
42Grand
Josh
I'm surprised nobody has mentioned blinker fluid yet...:hahano:
Garcjay
