Battery warning light
robe338
Ive got a question about the battery warning light wiring.
Its a 1984 silverado and ill be using a 1990 suburban cluster.
On the truck side of the bulk head I’ve got the brown/white wire. It goes up towards the cluster then loops back to the fuse box to a 20 amp fuse. I can no longer read the writing on the fuse box.
It looks like I need to add a wire to slot 5 of the cluster connector.
Do I just splice into this wire, leaving it hooked to the fuse and add the splice to the cluster connector?
or
Is the brown/white wire on my 84 for some other circuit?
The screw driver is pointing to the fuse that the brown/white wire is connected to.
Thanks.
twzorek
