Backlash adjust??
Status
Not open for further replies.
thaifighter
Banned
chilliwack british columbia
brian
k20custom deluxe 16.5 rims
350 sm465/np208
So what's the best way to do it and what should I be on the look out for?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Set up a dial indicator and see what she's got! Greater than 0.012" you should probably tighten it up a little, but no tighter than 0.005". With the spanner nuts on either side of the carrier backlash is easy to adjust.
thaifighter
Banned
brian
350 sm465/np208
So with a gear set this old I guess its not unheard of to need a little tweek?
crazy4offroad
K-10
350/SM465/NP205
Depends more on mileage than years. A dial indicator would tell you for sure. The carrier spanner nuts have these wire holders that hook in holes in the spanners, you could probably just loosen one side to the next set of holes and tighten the other side to the next set of holes and bring it in. IF it is indeed out. NEVER go by eye or ear on something like that, too tight is just as bad as too loose.
thaifighter
Banned
brian
350 sm465/np208
Thanks Curt I was hoping on getting youre opinion on this dont worry Ill be setting up the dial guage to determine if Im within specs:happy107:
crazy4offroad
K-10
350/SM465/NP205
Take pics, I want to see the condition of the ring gear teeth! If the backlash has been loose for a while the teeth's edge will get knifed down, you should have 1/8" of flat edge on the teeth instead of a sharp edge.
thaifighter
Banned
brian
350 sm465/np208
I just picked up this rearend today I plan on setting up the dial guage tommorow
crazy4offroad
K-10
350/SM465/NP205
Oh **** yeah, that ring gear looks great. No shrapnel in the gear oil or bottom of the housing? I'll be at the races all day tomorrow so it may be late tomorrow evening before I can check back on your findings/progress.
Good job Curt. :)
thaifighter
Banned
brian
350 sm465/np208
Well My asumptions were off by several thousandths
turn out Im right in ideal range .007 I guess I was just being paranoid lol:gr_grin:
Status
Jleopard77
