Axle stamp 41 10 = what ratio
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Im looking to get a set of axles, was wondering how the 41 10 gears would work with my 350 ci & 700r4? The back of the ring gear has a little surface rust, was wondering if it would be a concern? The guy said he left it uncovered for a little bit. Ill post up a pic in a bit, my phone won't let me.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
41 divided by 10 equals 4.10 ratio. Always take the ring gear and divide by the pinion gear.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
This is a pic of the #'s on the ring gear, if you look closely, you can see some fuzzy surface rust starting to grow on the carrier itself. Is that a cause for concern, or can I remedy that with lube, rust inhibitor, etc?
Driver4r
Nebraska
Trevor
k10,c20
I would just drive it.
Its fine. Theres no boulders in there,
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Question, did any GM 10 bolts come from the factory with 4.10 ratio on a half ton? Reason I ask is, the guy says he's never touched the gears.
Driver4r
Nebraska
Trevor
k10,c20
Do they say GM? But i dont know if they did in the 10bolts. My 12 bolt came factory with 4.11's tho.
gpmorgan
Tupelo Ms.
greg
The 410 gear and 700r4 will run 2500rpms at 70mph. I have that set up in my truck. That little bit of rust is no issue.
twzorek
