JohnRod
- Jul 9, 2017
- Kingman,AZ
- Rod
- 2500 Suburban
1976 C-20 Suburban, 350 2wd,
I have the same problem as several others with a wacky reading temp. gauge. the needle would go way past hot and then vary around. I ran a new wire from the new sender to the green wire just before the plug in. no change. after that, the needle would waiver when the turn signal was on, and the volt meter was way low, and the needle would waiver when the AC was on. so today I cleaned both Bat. terminals, the ground cable at the Alt. and ran a new #10 ground strap from the Bat.- to the body. and I cleaned the area where 2 wires ground to the emergency brake bracket.
the dome lite appears to be some brighter. the temp. needle no longer varies when the turn signal is on and the Volt meter is where it should be-engine running. so some progress.
however, the door jamb lite switch get hot. hotter than you want to hold on to!!! something, somewhere is really wrong. either a ground problem somewhere I do no know about or some type of feedback problem.
I have no idea what to do next. any help?
thanks Rod in AZ
PS, I cant download the wire diagram
thanks Rod in AZ
