All-Wood Flatbed?
adaml23
Decatur, IN
Adam
Scottsdale
So it's getting close to the end of the warmer weather and I'm debating on how to get this truck usable during the winter months...
I'm thinking about building an all-wood flat bed just so I can get this thing on the road. It currently has no bed but I was able to finally get it started for the first time in close to ten years last Sunday and just need to get a bastard u-joint for the driveshaft to work with the newrear end and rear brake lines ran to get it moving (that sounds easy enough but I'm sure other things will break on me once it starts moving :Insane:)
So, my question is has anyone ever built a homemade wooden flatbed? If so, please post pics, plans and suggestions.
Thanks in advance!
Georgeb
Wisconsin
George
K10 Burb Z71
I havent done it personally but have seen it done. It's a good option for temporary use in my book. Treated lumber would be best. I think using the stock bed bolt holes to hold the 4x4 cross beams on would be a start Then cap the ends with a 2x6 and lay 2x8s the long way. Use carrage bolts and lag bolts as much as possable with liquid nails in every joint as well. I saw one made out of treated last several years. The guy treated it every fall with thinned out oil base stain top and bottom.
ht_8063
