Aftermarket fuel tank
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Where is the best place to get an aftermarket fuel tank that I can put in the frame rails under the bed? I know that LMC has one, but wondering if there are any other places that have something that would work.
Already very tired of the saddle tanks.
Thanks.
Brandon
Green79Scottsdale
G.R. - MI
Bob
A lot of guys simply get a tank from a Blazer/Suburban and use that. No matter what tank you end up getting, there is going to be fab work to get it between the frame rails. And you need to figure out the fill part too. Somewhere on here is a thread about it I believe. http://www.gmsquarebody.com/forum/showthread.php?t=663
How are the saddle tanks causing problems, if I might ask?
donmateo
WI
I got mine off of RockAuto and they seem to be good. No issues thus far.
firebane
Calgary, AB
Curtis
Thanks.
Brandon
Whats wrong with the saddle tanks? They work and are easy to work on lol.
1low4x4
Nick
**** I prefer saddles. More freedom for exhaust routing
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Just ask Firebane. Let's see where do I start. I finally discovered that my gauge is operational, however it's not reading a fuel level of any kind in either tank. The sending units are working as far as I know, I've replaced the switch valve and the switch in the dash, which is wired correctly as far as I can tell. Still doesn't work.
Truck stopped 3 times this morning on my way to work due to a lack of fuel getting to the motor. Oh and my have a Carter electric fuel pump so that's not the problem.
One tank with no switch to have to deal with just might make me a happy man.
Georgeb
Wisconsin
George
K10 Burb Z71
I did the tank swap to the 32 gallon blazer tank. It was really easy!
1low4x4
Nick
I would LOVE 32 gallons. This one 16 gallon tank in this k10 goes empty so quick its unbelievable. Especially coming from 2 20 gallon tanks in the c20
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
So it looks as if I can get a tank and all the hardware from something like a 80' Suburban and just mount it in the back.
True?
Georgeb
Wisconsin
George
K10 Burb Z71
True?
Yes, It was easy for me because of my home made step side box. I had a place to go with my spare and was able to fab up a filler hose mount. wherever I needed it. With a fleet side you will need to cut in a filler door unless there was an option for the filler behind the license plate.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
OK cool. So I would need a tank, tank straps, sending unit, filler neck and cap.
Am I missing anything?
I see that Rock Auto has it all and it would be less than $200 bucks.
Georgeb
Wisconsin
George
K10 Burb Z71
You will need to extend your lines as well. And i believe there was a cross member and upper mount bars or somthing like that.
Georgeb
Wisconsin
George
K10 Burb Z71
I will be getting that truck back home this weekend so I will be able to post some pics of this provided the thread stays alive to remind me.
firebane
Calgary, AB
Curtis
Hold on.. You have a electric fuel pump on a 73? I think you REALLLLY need to explain your entire fuel system to us. Electric fuel pumps need a regulator as well as a return line usually.
If your truck is dying it could be vapor lock.
aaron06
