88 sub rear
royc
long island ny
roy
K 10
Is there a 14 bolt that has 6 lugs that would fit under a 4x4 sub
I'm looking for a stonger rear and a wider axcel shaft rear thanks Roy
Swims350
Logan WV
none
14 bolt with 6 lugs is a semi floater, or sf.
a full floater is 8 lug.
you should be able to find some rom like a 3/4 truck or blazer, even burb.
the newer gmt400 style I do not think will work because the spring pads are different widths. Now if you can weld them in the correct place then any would or should work.
As for being wider, not sure, I can't remember if the gmt400's are wider or the squarebody ones.
GMT400 style is the only one available with 6 lugs. The 4x4 version is wider than the SB axle (which is good), but the 2wd version is a little narrower.
Swims350
Logan WV
none
aahhh ok.
I get confused on them all the time.
only thing I knew for sure was 14 bolt sf was 6 lug and 14 ff was 8.
aahhh ok.
Most of the 14 SF's were 8-lug too, even in the GMT400 years.
:popcorn:
Bigskygearhead
