'88 K5 RH Hinge Cover Cable Routing Question
trukman1
Gary
K5 Blazer
5.7 L (350)
I purchased an '88 K5 with a broken release cable. I removed it to clean the seats and, of course, I didn't take any pictures. It took so long to find a replacement that now I can't remember (or figure out) how to route the cable. Can anyone take a picture of theirs for me or direct me to an online picture. All my attempts have come up empty. I know its a lot to ask but I'm at a dead end. Thanks.
ETA: I should have left out the word "cover" in the title. Old and goofy. What can I say?
From what I remember, it just attaches to the recline mechanism, then goes down and forward to the release lever on the seat track.
trukman1
Gary
K5 Blazer
5.7 L (350)
That's what I thought. Seems simple but it doesn't seem to work that way when I go to install it. I've spent a lot of time trying to Google it to find a picture without any success. I'm hoping I didn't get the wrong hinge. Bought off eBay and was supposed to be for my vehicle but without a picture I'm totally at a loss.
And I'm still lost. Is this to the driver seat were talking about?
Passenger seat. When you tilt the seatback forward for rear seat access, it pulls a cable on the seat tracks, so the whole seat slides forward on the tracks too.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Most times I have ever seen the cable is broken and gone and the dash does a great job of stopping the seat when you kick it forward so it wasn't worth investing time in caring about it... If you want to be OCD about it go to your local Ace hardware and find some small gauge stainless cable and get some buckle ends and have someone show you how to make a loop and clasp it if you can't figure out what to do... If you really want to OCD the OCD compulsion while you are there get you a can of the black plasti dip that you can dip your tools and stuff in and you can rubber coat it after a few dips...
That's a different cable. You are describing the earlier seat where the whole thing tilted forward. That's just a limit strap so the headrest can't bust the window. The seat setup changed in '85 or '86. Can't remember which.
Ahh OK. Guess I got lucky then. The passenger seat on the K5 I just bought has a lever that gives access to the rear seat and it works just fine. it comes forward like an ejection seat and all the way forward at the same time or with the 1 lever.
trukman1
Gary
K5 Blazer
5.7 L (350)
This is the type seat I'm talking about. No matter how I try to route the cable it just doesn't seem to fit right. Without it properly hooked up there's literally no access to the rear seat. I thought I would be able to find a picture of it online but so far no luck.
ETA: Spelling correction.
trukman1
Gary
K5 Blazer
5.7 L (350)
My above reply may not have been correct. This is what my seat is supposed to do, slide forward with the back tilting forward. Can't get the cable installed so it functions this way.
Is it under the seat cover? Is it something that one of us could look at our and get pics without taking the seat cover off or out of the truck? I'm sure someone would be willing if it's reasonably possible.
It's under the plastic covers on the side. I've got all the parts to show it, I would just have to get them all dug out from various places.
trukman1
Gary
K5 Blazer
5.7 L (350)
I would greatly appreciate any pictures anyone can send me. A picture of it installed would be best since I have the hinge with cable installed that I purchased. I realize taking the plastic covers off would be a pain but if anyone could shoot me a pic I would be very grateful. Thanks!
rpcraft
Robert
Jimmy
LS 6.0 364 CID
See I am used to the one that was on my 77 and my 85 is getting the Tahoe sits on custom brackets...
trukman1
Gary
K5 Blazer
5.7 L (350)
Finally figured it out. When I mounted the cable the way it looked like it should go, the plastic piece at the top would bend w/o letting the seat move forward, so much so that I was worried it would break. Then my brother-in-law realized it would work when held against the seat. When the cover is put on it does just that...holds it in line so it can't flex. Problem solved!
Thanks for all the help guys!
FenderBanger
