87 tbi would not start
waterpirate
delaware
v10
5.7 tbi
So I ran the square down to the UPS store yesterday to send a package. It is about 12 miles. New motor ran great, temps normal. Was inside prolly 15 minutes, came out turned key, no go. Motor labored to turn over like it was hot? Hood up not hot everything seemed normal. Sat in the truck and waited 20 minutes. Motor rolled right over and started like normal???
Ran the square home, parked it, turned it off. Truck restarted immediately with no issues.
Anyone have any opinions on issue? Gremlin?
Thanx in advance
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Heat soaked starter?
That was my first thought, F-bodies used to do that a lot because the exhaust was too close to the starter. Do you have headers?
Or yeah it could always be some wonky electrical connection
waterpirate
delaware
v10
5.7 tbi
That would be a no on the headers. Heat soaked starter? Meaning it just got hot? I can check the connections easy enough. Solution for starter?
Poppy 87
Bloomingdale GA
R10 Silverado
I would check ignition coil first, then module
Sent from my XT1254 using Tapatalk
F-64
nyc
mike
R10 lwb
5.7 tbi stock
You may try a voltage drop test on the starter wire.
waterpirate
delaware
v10
5.7 tbi
Issue was resolved. 2 1/2 qts. low in the auto trans. I am guessing heat built up? Never happened again.
Yapay
North Carolina
Christopher
Might not be the same issue, but I had filled up one day and then the next couldn't get it started until an hour later. Happened two days in a row. turned out to be a tank of bad gas. could be a similar problem for you?
RecklessWOT
New Hampshire
Kevin
Doesn't sound like that's he case here. But something to keep in mind for those random "no start" scenarios that don;t seem to add up to anything else..
Yapay
North Carolina
Christopher
Definitely. I’m just not getting how a low oil level in the transmission would cause a no start. Air, fuel and spark. That’s really the only things.
loki1978
