86 gmc Sierra bogging no response
martingmc86
california
martin
gmc sierra 1500
v8 5.0
so my truck started with this issue when cruising at normal speed and flooring it it just bogs down doesn't die tho. if you stop at a stop sign floor it it only bogs down no response. About 1 month ago CEL was on i replaced the TPS (Acdelco) was working very good then i left the truck parked for 1 week now with this issue the truck idles really good if you rev hard there no issue I've replaced the fuel pump since i had low pressure haven't checked since then i also replaced the distributor cap and rotor since the brush was Broken please help
fast 99
Spokane, Washington
Fuel, was the pump Delco, AC or Delphi? Check it again.
Hard
