80 K10 Front Driveshaft Th350/NP25 to 10 bolt
Just posting this up in case someone might be looking for one. This one is wore out. The Double Cardan U joints are still OEM. Maybe it just needs some grease, but the yoke seems to be a bit loose over the splines.
It was pulled from a 1980 K10 that was OEM Th350 with a NP205 going to a 10 bolt front axle with Part time lock out hubs.
What do you suppose it would cost to ship that sucker to 43140?
Not real sure. I'd have to weight it. Bummer it won't fit in a USPS Flat Rate box. It's not light, but maybe UPS ground might have a fair rate. I'd have to get it weighed and my shipping scale got broke by one of my live in losers. I'd imagine I can try to find out for you.
I forgot all about this quote Andy. I don't have a scale to weigh it. What can it weigh? 10-12lbs? I'd have to look around for a box to ship it in. The zip code I'd likely ship it from is 73159, OKC, OK if you want to look around for a rate. I'll have to see about finding a scale to get a more accurate rate.
I think it might weigh more? I'll see what I can figure out. I'm also unsure if it would even need to be in a box, I think it can just be wrapped in tape.
78ALB
