79 vacuum routing from canister
Chevydad
Jason
v8
Vacuum line routing through firewall, does anyone have and be willing to post a picture of the firewall near the ac evaporator, particularly where the vacuum lines are running from the canister through the firewall, mine were not hooked up. Thank y’all
One line from the canister through the firewall is a thin plastic hard line and it runs through a grommet on the firewall, across behind the dash, and connects to the HVAC controls. The other line on the canister (normal rubber vacuum line) runs over to the intake manifold and is connected to manifold vacuum. There may be a multi-port vacuum connector screwed into the intake, or you will need to T into one of the other manifold vacuum lines.
Hit the forums tab go to ,square body reference library.
Chevydad
Jason
v8
Supporting Member Army
@Chevydad
Within that section are manuals and reference material for all years.
You literally just click the "Forums" button, not browsing within the dropdown. Then scroll down to that section on the page it takes you to(the forum homepage).
Chevydad
Jason
v8
Found it thank you, exactly what I was looking for.
Johns C10 Hubcap
