78 k10 blinker problem
Bka29
Nampa
Brandon
Hello. I have a 78 k10 5.7 350. My problem is inside my blinkers flash normal (left,right,hazards). On the outside, only the front blinks but the rears do not. I have tested the buss fuses and all are good. What is the problem thanks. Also if anyone has a fuse diagram to see if I am missing any fuses or wrong ones in. Thanks
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
You ran out of blinker fluid.
Sorry couldn't help it.
I would check the bulkhead at the fire wall. Pull it apart and clean it up. I find gm used this tar stuff. It gets hard after a while and hinders connections
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
From experience, theres a broken wire out near the end of the bed to the tail lights....
twzorek
