Dleslie212
- Sep 2, 2019
- Phoenix
- Dustin
- K10
- 5.7L 350
Purchased for $3200 about 5 years ago
Everything listed below has been performed by myself within last few years, with less than 500 miles driven since I've owned
Complete rear-end rebuild, new bearings, ring and pinion and TruTrac with aftermarket different cover
All brand new u joints
All brand new brakes, roots drums calipers
New brake lines to front
Brand new Wilwood master cylinder with prop valve
Converted to hydroboost - brand new
New alternator
Converted to EFI
Edelbrock ProFlo 4 system
Both fuel tanks brand new EFI style
Switching valve, later EFI style brand new
Selector switch new
Brand new wiring harness - Painless
All switches, bulbs, taillights headlights and side markers brand new
Anything electrical has been replaced. Neutral safety switch, hi beam switch, turn signal switch - literally anything having to do with electricity is brand new
Dual Yellow Top batteries with driver side secondary battery tray
Brand new Dakota Digital HDX gauges
Dakota digital GPS speedo module
Dakota Digital ProFlo4 module
Dakota Digital gear indicator module
Brand new still in box instrument bezel
Steering column was completely torn down and rebuilt last year. Four bolts retightened with loc tite.
Bearings in steering column replaced
Ball joint inside steering column replaced
Rack and pinion replaced
Ignition cylinder NOT replaced - still good condition and wanted to keep original key
Steering shaft replaced with new Borgeson u joints shaft
All leaf spring and sway bar bushings have been replaced with new Poly
Brand new (less than 200 miles) 33" Goodyear tires and brand new wheels
WHAT IS STILL NEEDED
This is an Arizona truck. No rust on frame but needs body work
Interior needs floor pan and cab corners.
All interior is gutted down to metal. Needs doors rebuilt. Needs dash pad. Needs new or refurbished bench seat
Exterior Needs body work to fix a few dents and Needs paint. Currently is just primer black
Engine doesn't smoke, runs strong but does leak oil, not positive from where.
350 small block, 2 bolt main
Trans is 700R4, currently without lockup circuit wired in
New alternator
Converted to EFI
Selector switch new
