'77 C10 350/TH350 ignition problem
Steppin Razor
Houston
S
C10 silverado
Hi all. Have an ignition problem I don't know how to solve on my 77 C10 with tilt steering. I replaced the ignition switch a few months ago. The other day at a store, I got in to go home and the key turned all the way, no ignition. So I had to unmount the switch and manually operate it. Got home, then hopped on my bike to run to pick up a new lock cylinder. Put that in, but it does not move the rod that is supposed to operate the ignition switch. Any idea how to dig into that to see what broke and if there's a part to replace it with? Thanks
Most likely the ignition rack.
Steppin Razor
Houston
S
C10 silverado
Thanks. Does anyone have a good youtube tutorial for this? I looked but could only find a video for a later model. I searched some threads here for ignition rack, it seems like people are describing taking more apart than the guy did in the video I found. Though I couldn't really tell because he jumped around a bit. The ignition rack was not his main repair.
Any other parts I should get to while I'm there? I've got the turn signal (for the 3rd time. Standard brand turn signals suck), and I already swapped the ignition switch. I have a new lock cylinder, though that does not appear to be the problem. What else? Also, anyone know where to get a replacement rack? I didn't see it on Rockauto or Oreilly. Thanks
Steppin Razor
Houston
S
C10 silverado
I'm sorry man sicker than a dog right now,I'll try to dig up some info,for you biab
Thank you. Part number helps a lot. I'll just follow the video I found and if I gotta keep taking stuff apart, I'll just keep going.
fast 99
Spokane, Washington
If tilt assembly is loose at all now is a good time to tighten the lower bolts.
Steppin Razor
Houston
S
C10 silverado
So I have been using this video to get an idea of what I have to take apart
It's a later model than my '77 but I don't know what year. He's got his wipers and dimmer switch on the column which I don't have. I got as far as 5:30. Took out the tilt spring. I cannot seem to get the collar that has the bearings in it to come off. It seems to be held in at the top but I can't figure out what is holding it. That looks like the last thing to remove before I can get the new rack on (old one was in fact snapped). His video skips the collar actually coming off.
Any idea what holds that collar on?
What lower bolts?
fast 99
Spokane, Washington
At 6:43 red greased area on top may be holding it. Part of tilt assembly. Should be able to release with the tilt lever.
Have the tilt pins on the side removed? Lock and key should be out to release and allow gear for the rack to turn.
There are differences between the early and later columns. Try to find a video showing style your working on.
Steppin Razor
Houston
S
C10 silverado
Thanks. Tilt pins are out (assuming these are the pressed in ones. I made a makeshift puller with an 8-32 bolt, wingnut and a 13mm socket), lock cylinder is out, sector gear is out. I even got the broken rack out. I unscrewed the tilt lever when he did, prior to removing the sector gear and the pin that goes through it. Do I need to put it back in, and if so, the pins and the spring as well?
I tried to find a video of my year but no luck.
Jgonick
West Texas
Joel
This might help- It goes into detail how to put the column back together.
You are probably around page 28. I would read a little before that page and through the next few to get an idea of how it goes back together.
jazzman- LINK-Inside the GM Tilt Steering Column
Steppin Razor
Houston
S
C10 silverado
I used a combination of the video above, and this video
Both are replacing the same thing, the steering shaft U-joint, but it covered what I needed.
However, both videos missed putting in the inner race on the outer bearing during reassembly. Didn't film it I guess.
Also, for some reason the key turn is super notchy. It actually gets stuck in the crank position so I have to pull it back. Is this just because the pieces are new? Hopefully it will smooth out. I greased everything during reassembly.
Edit: Definitely did something wrong. Aside from the key being notchy and not returning from crank when let go, the steering is much tighter and does not return to center when let go after turning. Any ideas? Did the guys in the video miss something else I'm not aware of?
mo4154
