76 C-20 will not crank over unless steering wheel is tilted down
tms481
Indiana
C20 Silverado Camper Special
I have a 76 C20 Silverado Camper Special with 454 engine. Over the past few years I have had to tilt the steering wheel down before the engine would crank over. This past weekend the truck started as normal. Shut it off and tried to start it later. Would not crank over. The steering wheel was tilted down. Notice a small amount of smoke from under dash near the fuse block when trying to start it. Seen no sign of any burnt wires. No fuses blown. Replaced ignition switch, still will not crank. I still think its something to do with the tilt steering. Any ideas would be appreciated.
firebane
Calgary, AB
Curtis
Steering column is possibly pinching wires underneath. Time to take a look and look for broken or pinched wires. This can and will create a short.
tms481
Indiana
Thanks for the suggestion but I have not seen any pinched wires around the steering column. Wondering if it could have a fusible link problem.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Funny thing is my '86 C30 does it too. Does not seem to affect anything so no big deal in my eyes. It will work once in a while with the tilt up, but mostly not. No idea. Its never been a big enough problem for me to tackle. Maybe when I dig in to replace the turn signal switch...
gpmorgan
Tupelo Ms.
greg
You probably need to adjust or replace the ign switch that's mounted on top of the column under the dash.
gpmorgan
Tupelo Ms.
greg
I reread your post. Did you get the new switch adjusted properly ?
highdesertrange
kalifornia
mike
k30
when you say you "replaced the ignition switch" do you mean the actual ign switch or the lock cylinder where the key goes? I just ran into this problem on a buddies truck. it would only start with the tilt down, so I adjusted the switch. it was good for like 4 starts then nothing. well come to find out the rack was broke where it engages the rod to the switch, there was enough of it there to work with the tilt down, but when I adjusted the switch it was to much for what was left of the rack and totally broke. btw those racks are pricy. highdesertranger
winterhawk
