74 LWB split drive shaft
Vitamin C
Holland, MI
Do both the small block turbo 350 transmission and big block turbo 400 transmission LWB C10 2WD trucks have the split two piece drive shaft?
Strick
Dunn, NC
Harold
C20 Crew
The TH400 will be a fixed yoke on the output and the front portion of the shaft will be shorter than a TH350. I'm not certain if a TH350 2WD two-piece has a fixed yoke or not. Maybe some of these other guys will know.
Strickland
Vitamin C
Holland, MI
Strickland
So you are saying both the TH350 and TH400 LWB trucks use a two-piece driveshaft!!?? Ill crawl under my TH350 tomorrow and see if it is a fixed yoke.
Strick
Dunn, NC
Harold
C20 Crew
The 2WD can have 2 piece shafts unless it's a TH350 long tail or 700R4.
wilson79
