- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Anyone have a driveshaft out of a 73-76 3/4 ton 2wd truck? It will need to be a small block truck with a Th350 so that it has a Th350 auto transmission.
I'm wanting to find a driveshaft for the set up. Or maybe at least some measurements and to know which U joints are in it. My Torque Converter has bit the dust in the C20. I'm thinking of putting a 700r4 in that truck. A driveshaft to a Th350 out of a square with a 9 in tailshaft should fit. But, I need it to fit the length of a 14B Full Floater, not a 12 or 10 bolt rear end, and I need to know if it will have the bigger 3/4 ton U joints so I don't have to use special conversion U joints and give up U joint strength by using a 1/2 ton driveshaft.
If anyone has one laying around and can gimme some measurements, or close enough to swap some parts, lemme know please. Thanks
