6.0 LS to SM465 (mechanical clutch)/NP205 compatibility question.
CheemsK1500
K1500
I'm considering getting an early 2000s 6.0 LS to put into my '84 K1500 to replace the tired 305. Is there any sort of special components I should look at to make this engine works with the transmission and transfer case I listed in the title? Thanks.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Need a harness forsure, mounts change up a bit as well, change out fuel lines
Backyard
Ontario
Nathan
If you plan on using an older trans you need to oblong the flywheel holes slightly to match up to the converter. You will also need to extend the alignment snout on the torque converter, you can buy that for abour 20 bucks. you need engine mounts I recommend going to ict billet they make things pretty easy for the swap and they give you lots of swap info. When it Comes to the mechanics side of things.
As far as wiring you can go with a holly set up ot modify your existing harness. It's a good amount of work to get everything working. I have done a few. Lots of information for wiring on lt1swap.com
You will need to update your fuel system. I recommend doing the suburban or blazer "fuel injected" because you would want the tank with the sump. tank swap and running an in tank pump. You can do an inline pump. I have done both but i don't like thr noise of an I line. That being said the inline pump is the easier route.
Hard
