500hp 350 carbureted and 700r4
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
It's not too hard to get there with a SBC but you'll have to stroke it. My 358 is close on pump gas but you have to have someone who knows what they are doing with heads flow and cam combination.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I am really trying hard to not sound like an internet ******** keyboard warrior but when you mentioned supercharger and not being able to afford running 91 octane all the time I had to post something. Shop around on the online speed shops for forged pistons, compare that to hypertueteicicicsiahalg whatever pistons.
Im with Hirshdale on the big block idea.
I just put one together for my C/1500 and its an absolute handful to drive. Its pretty much stock with the exception of the aftermarket sealed power pistons, a comp cams roller cam/ lifter kit and some fancy roller rocker arms. I am even running factory heads and tbi. Does not sound like much but its a runner!
Second good option is a really interesting one I was reading about. Apparently you can just find a LS series engine out of a wrecked car, install a cam and have 600 horses without building ****. I cant remember the article exactly but LS engines will get you alot closer for less money if you could find a good one.
Option 3 is for if you are dead set on building a small block, go buy David Vizards book on making big power with a small block chevy. It will tell you exactly what to buy and what to do. Its way better than advice like this ******** I am typing to you right now.
aba69x
saginaw texas
cody
r1500
i am going to put in a 454. if i wanted to do cam, headers, intake, and a carb could i be around 500-600?
Moderator Administrator
Yes you sure can, but you forgot one huge ingredient. These items alone aren't going to get it done through peanut port heads. You're going to need some heads. Does no good to take a big deep breath, and have a biggo exhaust for exhale when the heads will be your bottleneck.
chevyk10
WV
Daniel
1984 chevy
k-10
Yep heads is money well spent, but you can't just get any heads. You can have ports runners that are too big for your cam carb intake etc. everything needs to match.
And what I would do, is put all the money can afford into the heads, then build your motor around the heads. They are the key to everything into the motor and everything out of the motor. Then from there, you choose your stall for your trans, and your gear ratio.
aba69x
saginaw texas
cody
r1500
ohh. ok. so first is heads. then cam. intake. carb. then headers? what would be a good set of heads to use?
That's what I would do. Heads will always be your biggest expense, whether it be buying heads or having machine work done. The better performing heads you have, the better or stronger performing cam, intake, carb and exhaust you have. Also being heads are the most expense, then that's where you basically start with your budget, cuz the cam and other parts are real close to the same expense no matter what you go with other than, flat tappet or roller valve train.
Swims350
Logan WV
none
honestly big blocks cost more in parts and such to build then a small block.
my vote sbc, maybe do it out to 383, good heads and intake cam to match, maybe look into a matched kit for like $1500-2000 from summit, either edelbrock, dart, trickflow, tons of options.
I know the edelbrock victor heads claim 500 hp out of the box, and then you can get a victor intake and such too, but those are single plane setups and not the best choice for daily or street trucks, so tons of things come into play.
chevyk10
WV
Daniel
1984 chevy
k-10
I wouldn't want a flat tappet for a daily driver. Hydraulic roller would be the best. AFR heads if you want to open your wallet. Still want to get the right ones. Easy to get too big on a street engine. 500hp on a stock block is a Bit much but may be okay if you're not horsing it around.
Swims350
Logan WV
none
why would you not want a flat tappet for daily? they've been around forever and we've never had any issues with them.
Now a solid flat tappet type where you have to adjust the valves a lot of put up with the clicking maybe I can understand.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Why run flat tappet though when you can run a roller? Allows you to run a much more aggressive lobe without premature wear. More aggressive lobe ramp = more power with the same lift because you can open the valve faster.
Swims350
Logan WV
none
way too freakin expensive is why. almost $300 for a cam and not including the lifters, when you can buy cam and lifter kits in flat tappet for under $200 that's why.
I understand the advantages of roller and what not but my wallet don't allow it.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Thats where the LS engines shine...the tall, narrow intake ports. Volume+velocity=yeeeeeehaaaaw!
chevyk10
WV
Daniel
1984 chevy
k-10
Where I'm from if you say "flat tappet" that means solid. Even if that's not technically correct. Lol
rgorma01
