4x4 shifter in 2wd cab
86chevyk20
Buffalo
Liam
soo i put a 2wd cab on my k20 because it was a decent find. its an 1985 cab and i have a bolt in hump from a 70's. iv got a 208 case, will this work if i were to bolt in that hump.? Or what if i were to leave the stock hump and just cut a hole out and make my own shifter like out of an aftermarket type thing?? ideas??? pics please?
Thanks
Liam
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
The hump goes back under the seat a little, I had to cut the bolt flange for the bolt-in hump and the t-case hump back under the seat out of my K cab and weld it into my C cab. If you dont have that option you can just put a 2" body lift on and get by.
If the donor cab was a manual tranny, it should already have the high hump. If not, you have to do what C4 says.
86chevyk20
Buffalo
Liam
ya the hump fits flush under the dash but has about a 2 in gap at the seat i was going to maybe make a patch but that made me think it woulndt work
crazy4offroad
K-10
350/SM465/NP205
If you still have the K cab look at how the hump for the t-case goes back under the seat. You'll have to have that to clear, otherwise just body lift it. I dont know if a hockey puck lift would be enough though.
86chevyk20
Buffalo
Liam
soo the bolt in 70's hump will not work???
crazy4offroad
K-10
350/SM465/NP205
It will help you clear a manual trans but not the t-case. If you have a large gap at the back of the bolt-in hump you can see that there is more to that floor pan that goes under the seat for it to really "work". I would have to take my bench seat out to get a pic of what I had to do. Dont know any better way to explain it, other than look in a K cab truck that doesnt have a seat in it to see what I'm talking about.
86chevyk20
Buffalo
Liam
the 70's jump did work got it in thanks guys
FenderBanger
