4l80E Limp Mode
Ugliergolem
Colorado
Garrett
V20
I have an 87 chevy V20 with the 350 and swapped my TH400 for a 4l80E and used the E-Z TCU transmission controller and it worked fine for a small while and now I can start it and it works fine and then after a short time of use it goes into limp mode and wont come out till I turn it off. I have gone through the entire wiring harness and all the wires are good and I even took the pan off the transmission and checked everything in there. I changed the speed sensors and that seemed to fix it for a short time but I am at a complete loss so any help would be appreciated.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Have you talked to tech support for the controller? Sounds like could be a hardware issue if it’s intermittent.
Ugliergolem
Colorado
Garrett
V20
I have, there is a small blue light on the controller and if it is flashing then there is a problem with a signal somewhere but if it is solid then there is no problem and the transmission and computer are talking fine and I always have a solid light.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Pressure/temp sensor thats mounted on valve body maybe ?
Ugliergolem
Colorado
Garrett
V20
Are you talking about the pressure valve solenoid? If so I just got done testing it and I couldn't get an ohm reading off of it. Are there particular symptoms of a bad or failing pressure valve solenoid?
Vbb199
Salisbury NC
Vince
On the VB, inside the pan,
imyourhuckberry
