4 wheel drive stuck won't go back into 2 wheel drive
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
Hi guys I wanted to test my 4 wheel drive in my 87 k5 blazer Silverado and I go out lock hubs put it in 4 high seem fine then I try my 4 low seemed fine then I wanted to put it back into 2 wheel drive then I went out to unlock my hubs then I tried to put it back into 2 wheel drive it would only go from 4 low to 4 high wouldn't want to go back all the way down to 2 wheel drive is it because I need to be in neutral and not park or I need to change transfer case fluid?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I've always switched back and forth with the engine running and trans in neutral.
jetman
Minnie, AK
Don
My own is like skysurfer's. It will not go into 2WD while in park, I have the best luck with the engine running, truck at a slow roll, tranny in neutral, then slide 'er into 2WD.
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
Ok thanks guys
macklemcole
