4 speed manual tranmission ?
thomas lipford
Florida
Thomas
C1500
I have three extra 4 speed manual transmissions for 78 chevy trucks. My question is i have a 78 chevy 4x4 it came with a automatic tranny and went out. Now the manual transmissions are for 2wd one ton trucks. I want to know if i can take one and put it in my 4x4? Will it bolt to my transfer case? Do i need some type of adapter to make them work or do i need to just scrap the idea? Its something i was wanting to try any help on the subject woud be nice
CSFJ
The manual transmissions will require a new output shaft to be installed, most likely custom splined, if available, or the input on the transfer case to be changed to match the factory 4x4 output shaft. you would also need to source an adapter to mate the two together. Also would need to source the pedal assembly and clutch linkage to make it work. Not impossible, but a lot more expense and work than rebuilding or replacing the auto.
Knightewulf
