27 FT Holiday Rambler
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I went back out to the camper a few hours later last night and it was down to 64 degrees inside. I set the thermostat up to 66* so it would kick off. I then set it lower again to see if it would kick back on. The Cool On icon just flashed again and nothing happened. Maybe it's because I'm trying to turn it back on too soon and there's some kind of safety built into it? But that wouldn't explain why it did that the first time, before the AC kicked on...
I know my home thermostat does have a time out on the AC control so it will give the compressor about 15 minutes to bleed off before attemping to restart. Apparently you can smoke a compressor if you try to restart it while it still had residual pressure?
Kevin Cloud
