208 grinding,will it last ???
MrMarty51
Eastern Montana
Martin
83 GMC 1500 TH350 NP208 transfer case will not pull in 2H or 4H,it just sits there making these bad grinding,bumping noises.
It does pull in 4 low without any kind of noise but it do`nt go to fast. :emotions33:
Just curious as to how long You people think it might go before completely breaking ???
The guy what owns it is real broke but He will be getting a 89 Suburban before the end of next month at which time the TBI and drive train components from the Suburban will be going into the Pickup.
MrMarty51
Eastern Montana
Martin
Anyone.
Any speculation as to what went wrong with this transfercase.
why would it pull in 4 low but not in 4 or 2 high.
I thought if the chain went bad that it would not pull in any range except for 2 high.
Just trying to figure this thing out but My knowledge on transfer cases is very limited.
I don't know either. I would drain the fluid into a clean pan and see what it looks like.
MrMarty51
Eastern Montana
Martin
I`ll do that when He gets over here with it sometime.
We wo`nt be repairing this transfer as the one in the doner suburban will be going into it.
Maby,after the parts from the suburban are instilled into is pickup I`ll tear it apart and look see what went wrong,if it`s not too bad I might do the repairs just to have it in case somebody needs a good one.
There will be a lot of parts from the suburban that I will be offering up here when We are done with it.
good hood,front clip,interior pieces,etc.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
The shifter linkage probably needs adjusted.
MrMarty51
Eastern Montana
Martin
I think it is as You said.
The guy that owns the pickup got to messing with the shifter and the four wheel drive is now working.
I havent had a chance to get it into the garage to check it out yet.
I thought that it was awfull goofey that He had four low but no other positions worked.
Thank You very much and that goes for all of Youse guys.
:popcorn:
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
its probabbly the shift fork the get spead open and fall off the collar
not sure what t case this pic is just found it on the web real quick. but it shows how the shift fork is. they are a comon problem with the 208. its not a hard thing to fix but you need to get a good shift fork and tear down the 208.
MrMarty51
Eastern Montana
Martin
OK.Dont think We`ll be messing with that T case as He is buying a 90 Suburban and He wants to take the components from that and install them into His 83 1500.
The engine in the Suburban has had some work done to it,but,the guy that owns it run out of time,His wife`s pregernant and He was needing the bucks.
One exhaust manifold need put back on,lifters adjusted and probably a few other things to make the Suburban run.
I told Ricky that We`d better finish getting the burban running and make sure everything is functioning properly before We go parts swapping,just in case there`s a pwoblem with any of the burban components,going to TBI His 83.
Now,is what I am hoping for is that after We gets that burban fired and running that he will decide that He likes the Burban tooo,then,We`ll be scrapping for another vehicle for a parts doner,then,He might like that one too and,,,,,,,,,,,,,,,,,,,,,,,,,,Where does it end? :Violin: :beatdeadhorse5: :leghump::drink_nl:
aaron06
