2.5" rams horns
MikeB
Looking at my engine and crossmember, I'm thinking that 2.5" rams horns will fit my 82 C10. Does anyone know for sure? Is there enough room to connect a head pipe without having to make an immediate 90 degree bend?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I have a K20 so I'm not sure if anything in your suspension would be in the way but I had 2.5" rams horns put on my truck. The driver's side motor mount clamshell gets in the way a bit and had to be cut then reinforced.
picture.php
picture.php
picture.php
picture.php
I've seen ram horns on a square before. I just can't recall which ones they were. I don't remember now which is which. Is it the left side that dumps straight down, then the passenger side can go either straight down, or angle toward the rear. I believe the difference being, truck manifolds, or passenger car manifolds. I'd imagine there is actually more than 2 different sets.
77 K20
Montana
K20 5" lift
HT383 fuel injected
The 2" ones have a difference side to side. Think the passenger side is s rear dump.
My 2.5" are both center dump.
MikeB
77 K20 -- Thanks, man. That's just what I was looking for.
I have looked at lots of headers and cast iron manifolds, but keep coming back to these 2.5" smoothies. Unfortunately, the 2" versions that slope back have ugly holes for AIR.
Those will be some good breathing manifolds. I'd rock those all day long over headers for a street truck any day of the week.
MikeB
Yeah, I'm leaning that way, even though I'd have to trim the clam shell as shown in 77K20's post above. Wish I would have known this while the engine was still out of the truck,:Insane: but I thought the only clearance issue I'd have would be the crossmember, like I had on my 69 C10. But it's less of an issue with my 82's crossmember.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
My stepdad said the ram horns are outlawed in dirt track racing because they flow too evenly. Not sure if that is still the case, but when he was a race team mechanic back in the day they were outlawed. I prefer them too and would switch over my 81 to ram horns but the visual portion of the emissions testing makes me want to stay with the stock manifolds.
MikeB
I ended up buying a set of stock manifolds for 96-2000 Vortec 350 engines, which fit my 82 chassis well. They don't have the flow capability of 2.5" rams horns, but my engine will rarely see more than 4000 RPM.
I really like the way they exit in the rear, especially on the passengers side where the head pipe will clear the starter by 4 inches. And plug wire routing is crazy simple.
If I ever replace the 2.73 axle with a 3.73 and upgrade to a 700R4 trans, I'll switch to something like Doug's headers.
MadOgre
NA
NA
NA
NA
NA
Those are exactly what I am using and I really like them for fitment and they seem ok for performance. I don't seem to have any breathing issues. I had the same ones on a HO 350 Target Master engine and that engine hauled ass! So I assume they breathe well but have never test compared to any thing else so Im just guessing! I think they are the nicest looking only 2nd to those 2.5" straight Rams Horns.
I see there are a few adds for those Rams Horns for pretty cheap so maybe I will pick a set up just for fun. The only thing is that you need to completely re route the exhaust to run them :whymewhyme:
MadOgre
NA
NA
NA
NA
NA
Where did you get those from ?
78blazer
