1988 V30 Tach
Scottycutlass
Elkland PA
Scott
V30
I got an 88 V30 454 carburated. I have a factory tach I found and want to hook up. On the HEA cap there is a yellow wire plugged into the tach port. Where does this wire go and what might it serve. It looks factory because it is built onto a double plug in with the power wire.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Computer maybe?
Scottycutlass
Elkland PA
Scott
V30
it looks like it goes to the emissions control, but i do not have tbi or an electronic card. Could I use an Autometer tach adapter?
How does a factory tach signal work?
I see lots of people wanting to install tacks on 1987 to 1991 square bodies but it seems like every forum gets high jacked by some other topic.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Is it a an original carb truck? I know a few were made. The VIN will have a W in the 8th digit.
There is an engine speed switch which controls the A.I.R. diverter if equipped with A.I.R. and that will have a wire going to the tach terminal.
Either way, the adapter should be fine if you want to go that route. I doubt just piggy-backing the wire that's there will hurt anything either.
Scottycutlass
Elkland PA
Scott
V30
Thanks for the information.
It is an original cab truck with the W code you pointed out. I found it in Rochester NY. It has been sitting untouched in a heated garage since 1992 with only 31000 miles. Its also a Silverado packaged truck with all the power options and 4 speed. They bought it for their tow business and started to paint it blue to match there fleet and never finished it. It will be red as it once was and I installed a hoist and will be placing an aluminum flat bed on it.
RustyBoltGarage
