1987 tbi engine timing question
allweld488
preston,iowa
chuck
k20
355 tbi
I am trying to time my 87 5.7 and the timing mark on balancer is at about 12 oclock and my timing mark on engine is about 1:30-2 is there a reason for this? how come it wont time to marks on engine.
rich weyand
Bloomington Indiana
Rich
There were three different positions for timing tabs on the SBCs. From straight up on the crankshaft, the timing tab locations were 5*, 35*, and 43*. Sounds like the engine tab is at one location, while the damper/timing wheel is for a different engine. Most aftermarket dampers/timing wheels are at the 35* position. That sounds like what you have.
You can verify this by looking at the front of the engine pully (using an inspection mirror), and rotating the crank until the keyway for the front pulley is at 45 degrees (1:30 o'clock as viewed from the front). That is TDC on #1 cylinder. Where is the timing mark on the wheel?
Easiest fix is to replace the timing wheel with the correct one, or put a cover on the damper with the correct markings. Another fix is to apply a timing tape to the existing wheel. Another way is to set an advance timing light with 30* more advance than you want. This should rotate the timing mark you see to compensate for the timing wheel being 30 degrees off.
Here's timing tape. You just apply it 30 degrees off the existing marks:
http://www.jegs.com/p/Mr-Gasket/Mr-Gasket-Balancer-Timing-Tape/746079/10002/-1?itemPerPage=60&pno=1
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Did you disconnect the tan wire on the firewall before checking the base timing?
scottybaccus
Central Texas
Scotty
GMC R1500
Last person to set it failed to disconnect the wire, so it is retarded that far. Set the timing. Turn it off. Plug in the jumper, and restart. Check the timing and it should be 20-30 degrees advanced.
blackghost
