1987 oil pressure gauge pegged.
1988 Bowhunter
Gilroy Ca
Stephen
k30
I have a 1987 crew cab dually one ton with 454. My oil pressure gauge is always pegged high. It never drops. I have unplugged the sending units etc. Even melted a hole in the gauge cluster lens and moved the needle to zero. As soon as the key is turned on the gauge pegs again.
Looking for advice on whats up with this
Thanks
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Electric gauges typically peg when their ground wire (the wire that runs from them, out to the sender) is shorted directly to ground. If you know where the sender is, remove the wire from the sender and start tracing it all the way to the gauge. Maybe it's rubbed through somewhere, either against something metal, or against another wire.
Thread moved to engine performance from Site News.
76Dump
