1985 c10 lower radiator hose cold
TheRealDylan
CA
Dylan
4.3 v6
1985 c10 with 4.3 v6
My lower radiator hose does not get hot, although the truck does not overheat. I have flushed the coolant, replaced the thermostat, replaced both heater core hoses, and ensured I have flow through the heater core. I am just confused about why the lower hose doesn't get hot while the top does. The top hose I read 150F, and the bottom hose I read 80F. Any help would be appreciated.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Either your water pump is not moving coolant, not likely since it does not overheat, or your radiator is blocked.
150 isn't even operating temperature,so your thermostat isn't open. Probably most of the cooling is being done by the heater core acting as a bypass. Get it up to 200* and see what happens.
77Dmax
vt
Joe
The lower hose should be cold. That's the inlet side after the coolant has been through the radiator. This is a non issue
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Good catch. I read it as 180. Should not have posted just before falling asleep.
When the thermostat does open both hose will feel hot. Of course the lower will be a bit cooler but not ice cold.
TheRealDylan
CA
Dylan
4.3 v6
Okay I will check tomorrow. I have a 195 thermostat in. I will also have to check again because I believe that when i looked at the temp gauge it read 210, but when using a temp gun on the top hose i would get 150. When I flushed the cooling system, there was alot of rust and overall very dirty. I forgot to mention that the inlet side of the heatercore hose gets hot.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
both heater hoses should be hot regardless if the thermostat is open or not.
I would take the temp. readings with a grain of salt. Those guns are not very accurate when checking temps of non metallic items. I have two of them. One is a Fluke that cost my company a good amount of money and a cheaper one I bought 20 years.
TheRealDylan
CA
Dylan
4.3 v6
All hoses get hot, but the lower radiator hose. Although I can feel something in the lower hose, I guess older hoses would have a coil/ spring in them to stop them from collapsing, and that may be what I'm feeling... Not sure. I guess this coming weekend I will pull the radiator and see if it's clogged. Would I be able to just pull the radiator and put water through it and see how it flows?
duncan_schawalder
