DonnyLee
- Jul 16, 2025
- Sandy, Oregon
- Donny
- C30
Hi Guys, working on getting my AC vacuum line source hooked back up to the control panel on the dash 1985 454. The trouble I have is it appears the Vacuum line feed has been cut off coming through the fire wall and have a small stub of what I would describe as the size on like a plastic manual oil pressure size vacuum line size that is black cur off by a Former Owner. What is this suppose to look like? Is it possible to splice onto the small stub that is protruding out of the firewall? Or am I better off running a new line to the temp control. I guess I am asking is where would I either source a new correct line, or the bits needed to splice this, and then connect to the QJ Carb? And where would I source them? Thanks in advance for you input/help!
