1982 c10 interior right turn signal
ramirezsl
tucson
jorge
5.3 ls
Anybody had any problems with the interior right blinker?? I recently purchased the printed circuit but still won’t work… does anyone know how I can start troubleshooting??? I’m guessing it might be my wiring
Jgonick
West Texas
Joel
Does it work with hazard lights?
Double check to make sure the bulb is making good contact and use a voltmeter if possible to check for volts.
If you are not getting volts, since you just replaced the printed circuit, check the connector to the printed circuit- look for the dark blue wire and make sure it is making good contact.- It should be beside a light blue wire on the connector (you could also check for volts there on the dk blue wire) The dark blue wire runs to the bulkhead. At the bulkhead -inside the cab- there should be two wires- one comes from the turn signal switch the other is the one that runs to the printed circuit.
-LINK- to other post where you asked the same question.
Broken85
Cumberland, NJ
A
Start at the bulb. You either do not have power, or you do not have a ground. Try giving it one of each and start working back from there.
75gmck25
Northern Virginia
Bruce
Did you reconnect the blank instrument panel ground wire to the grounding bus or post? If it’s not connected it causes multiple light issues when the panel “finds”another ground path.
Sad Sack
Nebraska
Goober
C15
Assume its a 194 bulb and not an LED 194 equivalent?
Original
