17x9 with 315's on a 4'' lift?
frankenstien
Fairbanks
mike
1500 Sierra Grande
383 CUI
long story short, my 285's are wore out, they were stretched on 7'' rims, looking to go up to 315's to match my 4.56 gears,
found a guy with good used set of 6 315/70/17 load range E's with 60% tread, its a pretty good deal
i need to get wheels anyways, looking at some pro comp 17x9 with 0mm offset 4.5'' back spacing,
the lift is a rancho springs in the front, ORD shackle flip in the back, its on a 1974 k10 with 3/4 ton springs and axles.
ive seen lots of 4'' trucks with 315/35's just not sure how offset effects these trucks
any pics of a similar setup or suggestions welcome, should fit ok?
glockholiday
Jeff
V10 Suburban 1/2 ton 4x4
Should be perfect.
tiredtiretodd
NORCAL
K 25
I just bought the Pro Comp Series 51 in a 17x9 with a 4 1/4 inch back spacing. I'm hoping they will work as well?!? I have a 6" lift and I'm throwing 35X12.50R17's on them.
boarder421
