12 Bolt Diff w/ LS, pinion stud issues
Sizemore
Maryland
Sizemore
I recently picked up a '77 C10, to use as a dump running truck while I renovate my house (and eventual project). Part of getting it road worthy I replaced almost everything with the brakes, and I decided it was a good idea (at the time...) to replace the rear seals and bearings.
The pinion stud was a bear to get out and now even harder to get back in. The LS springpack has pushed the plates apart.
Is this "normal"? If so, any tips you gurus with the voodoo so well, give me guidance? If I wanted to eliminate it, what's needed for the change?
Thanks,
The S.
:wtf: :think:
Posted from mobile...
Sizemore
Maryland
Sizemore
This will probably explain the headache better.... I just don't want to jam tools to finagle the plates into alignment and damage gears as a result.
The S.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
The gears are hardened steel, you wont booger them up. You're trying to get the crosspin shaft back in? You threw me with the "pinion stud" thing. Just take a screwdriver, start the crosspin shaft in, pry the 1st one in place, you might need to lightly hammer the crosspin once it gets the tension of the 1st one on it, Then repeat for the rest, pry/lightly hammer it home!
Sizemore
Maryland
Sizemore
Sorry I'm not up on the laymans terms ;) I RTFM'd it and that was the name in the diagram/parts list. So that's cool, after taking this image I have the shaft almost "home". In trying to pry it in I chipped the bearing race (?) that the large spider gear sits in, will that be an issue?
Much appreciated with the previous input!
The S.
crazy4offroad
Curt
K-10
350/SM465/NP205
You mean the cup-shaped washer behind the spider that the crosspin passes through? It shouldn't hurt anything.
Sizemore
Maryland
Sizemore
I just read you post again. I'm referencing the larger spider gears that the axle goes through.
The S.
Sizemore
Maryland
Sizemore
I got that &$@%# pin in today. Now I can finish up my brake job. Just hope the chip I took out doesn't haunt me....
:whymewhyme:
The S.
crazy4offroad
Curt
K-10
350/SM465/NP205
That's a side gear and it should be fine but a pic would have been 1000x more help at determining if it will be ok or not (usually the case with everything). And we can say ****** here without being banned. :waytogo:
Sizemore
Maryland
Sizemore
Ask and ye shall receive.
In adjusting the brakes I was able to spin the axles without binding or issues so I think I'm safe.
The S.
crazy4offroad
Curt
K-10
350/SM465/NP205
That's the locking coupling. When one wheel slips the coupler engages and causes the other wheel to get traction. It is hardened steel and will chip but as long as it's not a big chip and it can still engage I would just run it.
Sizemore
Maryland
Sizemore
Cool. Thanks man! Now off to replacing the brake booster. Oi Vey.
The S.
aaron06
