12 Bolt, 6 Lug disc brake options
MtBraun
South Dakota
Hello - new to the forum. In searching this and other forums I see many options available for both aftermarket and DIY disc conversions for 5 and 8 lug axles. I have found a few aftermarket kits for the 12 bolt, 6 lug axles. Some of the 6 lug kits require either turning down the axle flange to 3.06" or upgrading the axles - which I was hoping to avoid.
Has anyone done a junkyard swap for this axle? If so, what did you use?
Thanks.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Thanks.
92 Blazer front rotors with the centers machined out, 10 bolt front caliper carrier with the center machined out with new holes drilled and a wedge block welded on. Uses front calipers but will need massaged and will need 1/4" longer wheel studs.
mick84
