1 ton wheels on 1/2 ton truck?
mrburitto
Casa Grande, AZ
Cody
K20 Cheyenne Camper Special, C30 Crew Cab Dualy
Instead of focusing on load rating (C, E...) look at how many pounds they can handle. All load range C tires do NOT have the same rating on how much weight they can handle. The bigger the tire, the more weight it can handle. Here is just some examples from BFG KO2 All Terrains... (all tires load range C)
LT235/75R15: 1,985 lbs
30X9.50R15: 1,990 lbs
31X10.50R15: 2,270 lbs
32X11.50R15: 2,535 lbs
33X10.50R15: 2,600 lbs
Figure all the ones listed above would fit on the rear of your truck. Also with these tires there is some sidewall tread to help protect it against punctures (and to help prevent getting stuck)
Have you ever weighed the truck with a full load of wood on it?
There you go, someone with an actual good suggestion. Even the load range E trailer tires I showed you were only like 2,800 lbs. This is a much better option. And if your worried about getting stuck in the snow get a winch. If your in the woods behind your house worst case you just winch it all the way home!
R8rPhan
California
Mark
1973 (1979?)
C10 long bed (Frankenstein truck)
Taller is better but not to wide. Wide pushes to much snow when it's deeper than a few inches.
As for breaking axles you can do that at any speed. If a tire slips then grabs when you have power in it u- joints and axles are weak in your truck. You have 10 bolt differentials I think. Not GMs best.
Not really planning on carry 'that' much load.. The problem I am faced with is that when I'm carrying a significant load, the passenger load rated tires available to me balloon out, exposing the sidewalls to sharp rocks, even the small ones (2 inch) that the logging companies like to put on the roads to prevent erosion and mud pits.... The tires have practically zero protection in the sidewalls...
I just want to be able to carry a cord of wood without worry...
R8rPhan
California
Mark
1973 (1979?)
I have only been looking at how many pounds they can carry.. The local tire stores have only been able to offer me up to 2350 per tire... 2,600 might do it..
Maybe I'll look on line further for something I can buy and have installed locally..
I have no idea how I could weigh my truck around here..
fussfeld
east coast
j
c-10
4.3 v-6 262CID
i would like to officially withdraw from this thread.
Thank you for allowing me to participate thus far.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I am pretty sure there were half tons that came with the 6.5 L diesel in the mid 90s that came with a five lug 14 bolt rear axle. Can’t say for sure if they were 15 or 16 inch rams. Being that it is a newer vehicle you may have better luck looking for something like that at the junkyard.
R8rPhan
California
Mark
1973 (1979?)
Posi/limited slip by any chance? I do want to put that on the truck at some point (same with my chevy van if I can ever figure out how to get cat converters for it that are affordable enough for the state to allow me to drive it again)
fussfeld
east coast
j
c-10
4.3 v-6 262CID
I think if you quit responding you don't have to withdraw your participation.
Yeah, but i wanted to rub it in that i was insulted that it was implied that my answer wasn't a "good suggestion." :D
Hey look, those cadillac ambulances MAY have had 5x5 wheels and thus you could put larger rubber on them since this was (the installation of a 14 bolt rear in a B-body) for commercial purposes.
Anyways, i'm officially done with the thread after this answer.
Thanks again.
fussfeld
east coast
j
c-10
4.3 v-6 262CID
i am going to temporarily suspend my withdrawl, only for a moment:
Not only do i withdraw from this thread, i CONDEMN this thread.:Angry:
Ok, NOW officially withdrawn from the thread.
idahovette
Weiser Idaho
Perry
K20-K10
Are your panties really in a *** or are you just funnin??
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Drink a glass of prune juice and let that **** go. Thanks for letting us know that you're not participating in this thread again. :sleepy10:
CSFJ
I think this is what you meant to say
Big Chip
Michigan
Kevin
C35
Hahahahahahahahaha!!!!!!
Big Chip
Michigan
Kevin
C35
I think he should stick with the electrical stuff or troubleshooting a squeaky belt if he gets that pissed about something that I'm not sure was even directed at him.
rowdy_80
