1/2 ton to 3/4 ton???
mac52
Las Vegas
Cam
Hey guys, does anybody know if the dana 44 and 14 bolt out of a 77 k20 will bolt into a 75 k10? I have the axles out of a k20 that I would like to put in my k10, but wasn't sure how complicated the swap over would be? Thanks!!!
CSFJ
The front should be a direct swap. You may need larger u-bolts for the rear.
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
Somebody please correct me if I'm wrong, but I'm pretty sure you'll need to alter driveshaft length too, unless you have the shafts from the K20.
Also, how complete are the axles? Drum to drum? You'll need the 3/4 ton 8-lug wheels too...
CSFJ
Yep, I forgot to mention the rear shaft. The front should be the same, depending on what t-cases are involved.
mac52
Las Vegas
Cam
Sorry should have been more specific i have ALL the running gear. drum to drum trany, transfer case, drive shafts, wheels the whole 9 yrds.
CSFJ
In that case, you should have everything you'll need.
Shak379
