Dave Nelsen here in northern Wyoming. Started working on Chevys in 1966, (1951 216 C.I. in 1952 Chev. car. FAST FORWARD after Nova's, Impalas, etc.
WyoAk
Wyoming
Dave
1983 K10 SM 465 subject: I have installed a fully dressed Blueprint 350 cruiser engine purchased from Summit Racing. Also required flywheel to accommodate one piece rear main design and starter to accommodate the flywheel. Here is the unknown: BluePrint nor Summit knows of any clutch/dust/inspection cover available. Factory cover does NOT fit one piece rear main and oil pan design. Hours searching. This MUST be a reasonable common swap. Also no answers on supplied/bolted in place Holley mechanical fuel pump as to pump diameter slightly touching the motor mount AND supply line pointing inside the frame rail and not having a return line for dual tanks. I will try factory designed pump. Any advice, VERY APPRECIATED.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
You can make your own out of sheet metal or try giving Advanced Adapters a call.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
animal
Lee
c10 silverado
350ish
:welcome:
:welcome:
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria.
ali_c20
Austria
Alexander
C20, K5
Post some pics of your setup.
#inspection cover: I think you have to modify a non fitting cover.
#fuel pump: You can grind off a little from the fuel pump housing where it rubs.
#fuel pump return: Run a fuel pressure regulator with gauge and return.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Yup search for a gmt400 with a 4 speed.
metro247
