82 C10 EFI Conversion project
82SquareBurb
Soddy Daisy TN
Derek
I thought this would be a good place to document my "daily driver" EFI conversion project on my 82 Suburban C10. So far I am still in the parts gathering phase, but plan to get after it once I have everything on deck. Doing the 87+ tank swap with sender and an Aeromotive 340lph pump feeding 650cc injectors. I guess these gen 1 small block remodels are out of fashion, but I just couldn't bring myself to ls swap it. That may be down the road though.
This project has morphed into redoing the AC system to R134a with a peanut style Sanden 7176 compressor, (this site has been a wealth of good info for AC info!) so that expanded to all new accessories with a type II PS pump, all mounted to the holley "water manifold" mid mount serpentine accessory drive setup. This will relocate the AC comp to the passenger side nice and tight to the block. So might as well install a new 4 row radiator and 14" electric fans. For the management, doing a Holley terminator x-max that will control the fans, fueling, ignition, the alternator (PWM signal) and eventually a 4L80E trans, among a few other things in the future.
Since I am still in the lego building phase I don't have many pics, but will try and update as I make progress.
Some intro pics - here is the truck, with my trusty navigator lol
Before shot of the engine bay - all original 350/700r4 that I rebuilt back in 2010. This engine will be replaced by a 421 stroker at some point backed by a 4L80E.
Manifold going together on the bench, this is the chi-com version of the Pro Flo XT setup with a 92mm TB and a 3bar MAP.
and just as expected, the injector fitment was goofy and triggered my OCD
Some redneck engineering to the rescue, used some spare nitrile o-rings to lift the injectors up so they don't pop out of the rails.
Much better fitment, I checked with 50 pounds of air to make sure I won't have any leaks once it's in the truck.
82SquareBurb
Soddy Daisy TN
Derek
Few more pics for now, (hoping these pics will spark some motivation for others if they are on the fence about EFI) -
Fixed the sloppy injector issue with the added o-rings and now no leaks.
Here is the new dorman 31 gallon tank going together
Once I get the fittings together this will be going in with a new 1/2" hardline, and will use the existing 3/8" feed line as the return.
From a 1:1 boost referenced regulator
I went with the low dollar motorsports sensor kit so we can scale them correctly in the termx software.
For those curious, this is why I didn't just go full ham on an Edelbrock EFI pro flo kit, I just didn't want to struggle with its limitations in the ECU, since I plan to make some pretty good horse-torques down the road with this setup. Will need all I can make to move this 4500 pound roach! This is my first real 'daily driver' build so it has been quite a learning journey learning about modern AC, Holley EFI, power steering and cooling systems. I have been dreaming about this for the past 20 years of owning this rig, so I am stoked to finally start on it. Will post more pics as I get along.
82SquareBurb
Soddy Daisy TN
Derek
Few pics of the cooling system going together..
New radiator with shroud, and dual 14" fans.
Here is the Holley 'water manifold' that all the accessories will mount to, it takes C7 water pump and accessories.
What it's supposed to look like with everything installed
I'd rethink that fan arrangement. With the fans against the radiator a shroud doesn't do anything. And the way yours is setup your shroud is going to be blocking a ton of air flow at road speeds.
SquareRoot
At least you didn't say the "S" word. Had me worried there for a minute. Can't beat a 6000# street racer. You might even up your mpg to 11.
82SquareBurb
Soddy Daisy TN
Derek
I'm definitely open to suggestions. My tuner suggested a brushless fan setup, but I opted for a slightly more affordable option for now.
Okay look at your picture of your shroud. How much of the flow area is the fan motors blocking,now how much of the flow area is blocked top and bottom by your shroud.From that pic it looks like you have 2/3rds of the radiator blocked. The purpose of a factory shroud the fan is back a ways from the radiator and the shroud acts as a funnel to draw air across the entire surface area of the radiator. If you look at many cars running electric fans and shrouds they have flapper doors so at a stop light the flappers are closed and the fan can draw a vacuum across the whole radiator. At road speed the flaps blow open and allow air flow through more of the radiator. Your setup looks set up to cool just a stripe in the middle section of the radiator and 1/2 that stripe is blocked by fan motors,at road speed even more will be blocked by the fan blades themselves. If was going to run electric fans
I'd mount them diagonal so I could cool the top and bottom of the radiator. I'd not run a shroud period. If I ran a shroud I'd pull it 3 or 4 inches back from the radiator,and put flaps in it. Also it would be a good idea to put a sacrificial anode in the radiator. Look up water heater sacrificial rods on Google,since most if not all water heaters have them,researching it that way will give you a better understanding of the purpose.
82SquareBurb
Soddy Daisy TN
Derek
Thanks, if I run into issues I can always upgrade to the spal 500watt units, and add a coupler flapper doors to the shroud. Seems the biggest challenge is moving air through the goofy basket style fans. Not really of fan of them, pardon the pun. I picked this shroud mainly as it's pretty sturdy and should hold up a while.
Bloodhound1981
MA
Rusty
C-10
I've been running this similar setup for some time now. In summer heat, traffic, with AC, I've never gone past 200. At highway speeds the fans shut off anyway and the air moves through. Highway is always about 182 or so.
Yours,the entire area under the fans is open and cools across 80 percent top to bottom. Look at his only like 30 percent of his radiator is cooled top to bottom. It looks like the bottom 4 inches and the top inches of his fan are blocked by the shroud itself,behind the fans. I'll look again maybe it's an illusion,but looks to me like only a stripe of radiator about 6-8 inches wide is exposed to the fans or even exposed to allow air flow Okay now I feel stupid,I blew the thumbnail up. I thought that area top and bottom were blocked.
ByrdDog
Amarillo TX
Robbie
Chevy
I think you'll be alright. I have a similar setup on a 400 Ford & it runs at 180-185.
Is there some reason you want to use electric fans?
I have the OEM 7 blade metal fan, severe duty fan clutch, aluminum 3 row radiator, high flow water pump, and stock fan shroud and I have never come anywhere close to overheating.
I think I could leave my truck idling in the driveway with the A/C on all day and it would just stabilize at about 190-195 degrees and stay there. If run for a while at 70 on the highway and then drop down to idle for a stop light I might see the temp come up to 200-205 (at idle) from the residual heat, but never any higher.
jbwhitford
