Hazards, one light
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Hmm, replaced turn signal switch which had new hazard switch on it.
So, waiting on broken button, but with screw in place I turned them on to ck before assembly. Just the drivers side front light flashes, not passenger. Turn signals and also fixed high/low beam, both work.
It's just the brown wire? So, new switch could be bad? But why one light and not both, or both not working? Errrr
350 w/203
Make sure your connector at the bottom of the column is seated properly and check for pushed pins and pinched wires.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Okay, I will.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
I checked the connector at lower column. I did hear a click from pushing together, meh. Checked wires for pinching etc. Turned on hazards and still missing passenger front.
I wiggled wires at driver front. Working now! For now! :rolleyes: :oops::laughing1:Couldn't duplicate with more wiggles, lol. Moving on.
Oh, cleaned and polished steering column, polished chrome parts.:waytogo:
Oliver90_08
