YakkoWarner
- May 29, 2024
- Central Texas
- Wolf
- R2500 Suburban
I always liked Pioneer units. I had one (badly installed by barely-post-highschool myself) in a 1984 Jeep that was rock solid. It was old enough that it was just AM/FM/CD - no bluetooth or front aux or USB. I still have the Jeep and the Pioneer didn't power on last time I had it running (last year) - but I fully suspect my dodgy inexperienced wiring of long ago is more at fault just no time to investigate yet.
I have a Sony unit which I am happy with in my smaller Ranger truck (which was transplanted out of a different car that died). The sony unit has to be at least 15 years old at this point and its still rocking. No bluetooth but it has a front-panel USB port that you can just stick a flash drive full of MP3 into and go.
My Suburban came with a very low-end Dual unit (comparable unit at Wal-Mart sells for $20.00 a couple years ago). It works OK...has no AUX in on the front but actual line input on the back - no bluetooth and its pretty anemic on power and headroom. I know I have a torn rear cone on one of the rear speakers - when I repair that I might advance to something a little higher quality.
I have a bass box with attached amps which I purchased from a co-worker decades ago. That has just been sitting under a side table in my living room because none of my vehicles had room for it - which should not be a problem in the Suburban. The active crossover was noisy though. If I want to resurrect that system I'd need a new crossover and it would have seriouly benefitted from a dedicated equalizer as well.
