Looking for new tailgate. 85 K5 Blazer.
CaseyM
Colorado
Casey
K5 Blazer
5.0 liter
Hello! I have a 1985 K5 Blazer Silverado and am looking for companies who manufacture or distribute new tailgate shells for mid 80s Blazers. I've made a lot of calls and searched online but I'm not finding anything. Any ideas? Thank you in advance!
warrpath4x4
Prosser, WA
72 K5/ 79 stepside/ 1989 suburban
Go with a soft top and you can use a pickup tailgate
CaseyM
Colorado
Casey
K5 Blazer
5.0 liter
Never thought of that, but my plan is to put a rooftop tent on the hardtop so it wouldn't be possible.
CaseyM
Colorado
Casey
K5 Blazer
5.0 liter
With 11 years worth of 80s and early 90s blazers needing tailgates, you would think at least one company would be producing them. It seems easy enough to find 73-80 tailgates.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Is this 80's?
warrpath4x4
Prosser, WA
That tailgate band is '73-80, don't know if they'll interchange on a Blazer
They will interchange, you just need the matching hinges and stuff from the truck. The blazer tubs are already pre drilled/tapped to bolt the hinges up
ZIMM78Blazer
Tx
I have a GM tailgate, I will sell. I live in south Texas. Dont know what shipping would cost. Its like new, no glass. Dont know what you are looking to spend.
Fat 454
Australia
C20 Suburban
Hi all - sorry what is the difference with the later model tailgates to the earlier ones ? Just the external body mould line at the top lip ? LMC sells up to '81.
I prefer good ( un rusted ) used parts to "new" stampings anyway. If you are in the high desert area you should have no problem finding a gate from a wrecker ??
I was talking about the tailgate trim band. That's a '73-80 trim band, the '81-up has a black border all the way around it inset ~1/2" from the edges. The '73-80 has a top and bottom raised ridge and is solid stainless all the way across. This is an '81-up
Hi all - sorry what is the difference with the later model tailgates to the earlier ones ? Just the external body mould line at the top lip ? LMC sells up to '81. I prefer good ( un rusted ) used parts to "new" stampings anyway. If you are in the high desert area you should have no problem finding a gate from a wrecker ??
From the outside, they all look the same. The main issue is the latch style, '73-76 is the "wedge plate" style. Then mid-year '76 they changed to the later style and kept that all the way through '87
This is the early style, '76-down. The gold truck is our early '76 shop truck:
This is the '76-up style. This is my '85:
They also changed the shape of the inset for '81-up. This means later tailgate bands can go on the early 'gates fairly easily but to put an early trim band on a later 'gate takes some modification because it's backer support is shaped different (it's mainly much wider) than the '81-up version.
So '73-76 has the early latch style, '76-87 has the later latch style. But all '73-80 have the earlier inset design:
And '81-87 have a revised version:
'73-80 tailgate band:
'81-up tailgate band:
C20NamedWaylon109
