Racer 238
- Feb 18, 2025
- idaho
- Ben
Doing an LED conversion on my 1978 GMC k15. Have all the bulbs swapped out with the LED ground flasher. Cut the blue wire on front side markers and grounded so they don’t flash with turn signals. The only problem I’m. Running in to is if I dont run an incandescent bulb in the front turn signals the turn signals won’t flash. The led buld seems to be stuck in bright sequence and drowns out any flash. Put the good 1157 back in and they work as they should even with LED’s in the rear turn signals. Do I need a resistor in the front TS wiring? I’ve tried several different brand LED bulbs with the same result. Just will not work with LEDs in the front TS. Any idea what I can try next? Thanks!!
