New to the Forum
eagle
Livermore,Calif
john
Hello, I have a 1978 Silverado that is getting ready for some TLC. I have questions regarding some things that I can do myself. I’ve done my research on different platforms but usually I’m still not quite sure on how to proceed. Currently I’m beginning on the weatherstripping. The truck was only 1 original owner and truck is in better shape than some its age. My question is regarding the installation of the cab and door. Do both require weatherstripping or does it go only on the cab? When I’ve gone on sites to order the weatherstripping it only shows for the cab. Anyone with some information on this issue your input would be greatly appreciated.. Thank you Eagle from California
dusterdude
US
mark
gmc c15
Welcome,good luck with your truck
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
Welcome from Texas!!
Beware if you have a Suburban. I still can't find rear door WX strip that is thin enough to allow the doors to close fully.
animal
Lee
c10 silverado
350ish
:welcome:
WFO
Texas Panhandle
:welcome:
Donald vonMinden
Dallas, GA
Don
K10 Silverado, and Blazer
350 both
Good morning and Welcome....!! I have a K10 pickup 1977 and the cab rubber goes all around the door on the body of the truck. Also, the door has a piece of weatherstripping rubber around the top, as it goes from the trim area at the bottom of the window near the door lock handle, all the way around the top to the area of the vent window near the upper door hinge so TWO layers of weatherstripping at the top of the door
77rig
